Serpentine belt routing help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 91K5, Jul 11, 2003.
  1. 91K5
    91K5 1/2 ton status
    Jul 5, 2000
    185
    Wichita, Kansas
    Hi guys,
    Replaced the water pump tonight in the K5 and now when I turn on the A/C the belt squeals really bad and threw the belt off once... I think I may have routed the belt wrong. The tensioner doesnt have to be pulled very much to get the belt over all the pulleys the way I have it and doesnt seem as tight as it should be. Any pictures or diagrams would be great. Thanks!
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Are you sure you have the correct length belt? Just remember that if the pulley has grooves in it, the inside of the belt faces that pully...If the pully is smooth, the backside of the belt faces that pulley...
    Also, make sure that you have no grease on any of the pulley surfaces or on the belt...There is something screwy...you should have to move thetensioner quite a bit to get the belt on ...
  3. 91K5
    91K5 1/2 ton status
    Jul 5, 2000
    185
    Wichita, Kansas
    I'm sure the belt is the right lenght as I replaced it not too long ago, and it wasn't doing this before I swapped water pumps.
  4. 91K5
    91K5 1/2 ton status
    Jul 5, 2000
    185
    Wichita, Kansas
    Nevermind guys, I figured it out finally. Thanks for the tip fortcollinsram, it helped me realize where I went wrong.
