serpentine belt setup?
Discussion in 'The Garage' started by 85 Jimmy, Apr 5, 2006.
  1. 85 Jimmy
    85 Jimmy Sheepdog Premium Member
    Dec 31, 2005
    1,912
    68
    Gulfcoast
    just wondering if any of ya'll know if a serpentine belt setup from a 99 S-10 blazer with the V6 4.3L will fit on a late model 350.
    just wanted to know cause i can get my hands on the setup for CHEAP maybe even free. (it's great working at a GM dealership :D )
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    yes it should fit, the front of the blocks is the same. You might run into problems though with the assories them self. When i did mine i had to put spacers on the crank pulley to get every thing to line up right
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    and remember, the water pump rotates backwards too. need a new one
  4. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    It should fit cause i have power pullies off of a 98 S10 on my 89 K5, And im pretty sure all accesorie bolt holes are the same.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    what is late model to you? 87+ heads have an extra hole that older ones do not have, so you can't install one bolt on the serpentine bracket(passenger side one I think). I ran for many thousand miles minus that bolt and never had a problem myself.
  6. 85 Jimmy
    Dec 31, 2005
    1,912
    68
    Gulfcoast
    the heads i have for my build are the centerbolt design heads. so 87+ would be those heads, right?
  7. 85 Jimmy
    Dec 31, 2005
    1,912
    68
    Gulfcoast
    and the problems with the acceories would be what? can i use the stuff like compressor, alternator, power steering pump, etc. and the only thing i need new is a water pump
  8. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you might have to swap the valve on the back of the power steering pump depending on what type of steering box you are using
  9. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    yeah it should work i run a pre 80's motor 350
    and a 4.3L serp setup
