Serpentine belt system
Discussion in '1982-Present GM Diesel' started by Blazr77400, Jul 15, 2002.
  1. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    Has anyone herd of a system for a 6.2 diesel. I keep shredding my A.C. and Alternator belts.
  2. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    you can retro fit a serpentine system from a 6.5L. You have to change the water pump, and the pulleys of course. I'm getting reay to do it some time in the next month or so.
    rugger
  3. Blazr77400
    Aug 31, 2001
    652
    Ogden, UTAH
    So what do you do with the A.C. compressor. Do you have to change it to the thin style? Also do you have to get all the brackets from the 6.5? Is there someone who sells used 6.5 parts?
  4. rugger03
    May 14, 2000
    829
    around
    I havent really looked into it all that far, i've laid the parts out, visualized where they will go etc. I dont have a/c. I bought a complete 6.5 engine/ with turbo and lots of extra stuff from a member on the board, engine had a scored cylinder. I also buy alot of parts from ebay. You just have to look around. I've only seen 2 early 6.2 trucks in bone yards. good luck , rugger
  5. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    To do the serpentine belt you will need the new style compressor. Also make sure the brakets are from the same year 6.5 motor.'92-95 have one style while I think the newer setup started in '96-00.
