Serpentine Change??
Discussion in 'The Garage' started by big jimmy 91, Apr 7, 2005.
  1. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Does anyone know if I can replace the serp. belt on a 91 GMC 1/2 ton 350 ,that has AC. to a belt for a non AC application (to by-pass the pump)
    Would it be simply different belt lengths or are there other things like the routing of the belt?
    I am asking because the AC pump seized solid and it's not really required up here (why waste money to fix it :haha: )
    Any help would be appreciated
  2. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    First off, send me your AC unit... =) and secondly, yes, you only need to change the length of the belt... just head over to the parts store and tell them you have a <insert engine size here> with no AC that you need a belt for.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    ehh, my non/AC serpentine setup has an idler pulley in place of the AC compressor so I don';t know about that.
  4. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I did a serp setup on my 71 blazer from a 91 cop car, I carry 2 belts, one short to bypass the A/C comp (I converted it to a compresser) and one long to run it, only thing I noticed is my idler pulley doesn't like the short belt at all, puts tension in a direction it wasen't designed for. Try to find an AC delete idler pulley.
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    PM Chris Demartini(forget if thats spelled right) he should have the part number for the idler pulley.
  6. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    LMC sells a bypass pulley/idrler to bypass the AC pump. I think it's like 35-40 bucks..
  7. big jimmy 91
    Feb 21, 2004
    639
    :thumb:
    Thanks for the info everyone.
    I guess I will just wing it with a short belt and if it looks like it will cause problems go to the replacment idler set up.
    Unless there is more to the story... :grin:
  8. paulmoon
    paulmoon 1/2 ton status
    Feb 11, 2004
    211
    Reno, NV
    Mine's set up like this. Got the bypass pulley from Chevy. Red arrow point to pully. Not sure how you would set it up with out the pulley because of the idler and tensioner. I'm sure there are numerous ways to do it. :grin:
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    mines like that minus the air pump idler. Don't see any reason for that to be there.
  10. paulmoon
    Feb 11, 2004
    211
    Reno, NV
    yeah, there's just a little bit of tension on the air pump ider pulley. Maybe because it's a "long" streach there? :confused: Probably work well without it. It came with the kit!
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    eh mines factory without it so :p:
  12. big jimmy 91
    Feb 21, 2004
    639
    I really appreciate the pics. , but I have an embarassing situation :blush:
    Because I am un-able to pony up for a membership yet I can only see them if you put them in the post :blush: (kids , mortgage , no job right now and an EX. dragging me to court again :mad: )
  13. paulmoon
    Feb 11, 2004
    211
    Reno, NV
    Try this;
    crap. That didn't work Go to my web page below. The pICS are in the Blazer project page. The very bottom of the page, far right. Two red X's. Click on them.
  14. paulmoon
    Feb 11, 2004
    211
    Reno, NV
    had to got he the test forum and practice! :crazy:
    OK lets see if that worked :blush:
  15. big jimmy 91
    Feb 21, 2004
    639
    :saweet: That looks awsome , Thanks for the pic.
    Now that I have an idea of what it looks like , I wonder if I could fab. one up on my own... :thinking:
  16. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    the loads on that thing I wouldn't even consider it. All you need to do is send a pulley and belt through your hood, just cause you cheaped out on a $30 part.
  17. ZooMad75
    ZooMad75 1/2 ton status Premium Member GMOTM Winner
    Apr 5, 2003
    1,015
    617
    Pueblo, CO
    Part number for the a/c delete pulley is 10118713. My last check on the price at a dealer I go to was $34.37.
    I would not run without the something in the a/c position as the tensioner was designed to have the pulley ride on the smooth side of the belt and the tensioner would not pull the right way to keep it tight. I've got the truck serpentine setup on mine and have left an a/c compressor in place since I've been too lazy to go get the delete pulley.
    I don't have the idler pulley where the air pump went. running a slightly shorter belt takes up for the lack of it.
  18. santana
    Jan 11, 2003
    1,483
    Mesa Arizona
    I don't run the air pump pulley either cause it never came with one. .
