serpentine conversion - alternator plugs not matching up!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BayouBlazer88, Aug 1, 2003.
  1. BayouBlazer88
    BayouBlazer88 1/2 ton status
    Jul 31, 2002
    353
    Lafayette, LA
    Today I was putting together all the serpentine brackets and accessories before I put them on the engine and when I put the alternator on I realized that the plug prongs were different than my old ones. Is there a way I can rig this up for it to work right or do I need to find a new wire plug?
  2. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    get your electrical pliers out and find the new style plug, cut, connect, pinch, done.
    85K5 3/4ton,14bolt,10bolt,9"lift,35"boggers,16.5x14 welds, big horse 406SBC/700R4 /forums/images/graemlins/k5.gif /forums/images/graemlins/angryfire.gif
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    GM has a conversion plug, part number is 12083462 and will cost ya about $20 from the dealer or GMPartsdirect.com
  4. BayouBlazer88
    Jul 31, 2002
    353
    Lafayette, LA
    Thanks. I'll look into it.
  5. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
  6. BayouBlazer88
    Jul 31, 2002
    353
    Lafayette, LA
    Just checked it out at Summit. With shipping its about the same price ($20), plus I already bought the one from GMpartsdirect. Then again I just ordered a reverse rotation clutch fan from summit so I wouldn't have had to pay the shipping from GMpartsdirect. Oh well, thanks for the info though.
  7. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    hey, can ya give me some details on yur serpentine conversion ? im interested in doing this some time in the future. my motor in my rig is a 77'. please let me know process. thanks.
  8. BayouBlazer88
    Jul 31, 2002
    353
    Lafayette, LA
    I'd recommend finding a donor vehicle from a junkyard and get everything from there. GM put serpentine systems in 88 and up trucks and 89 and up blazers and suburbans so find one of these. First off you'll need all new accessories including power steering, alternator, water pump, reverse flow fan, and AC compressor if you have one. However all of these can be purchased from any parts store, but it gets expensive so try to use what you can off the donor vehicle. What you'll need to find is the 2 brackets that bolt to each side of the front part of the engine as well as the bolts and the tensioner. I haven't put it in yet so I don't know what kinds of problems I'll run into but it looks pretty simple. The driver's side bracket has 5 bolts and the passenger side has 4. I'll probably have it put together in about 2 weeks. If you want, I'll take some pictures of the completed conversion and send it to you. Just send me a PM in a couple weeks and I'll hook you up.
  9. big d
    Oct 24, 2001
    1,236
    illinois
    sounds cool. thanks. ill pm ya in a couple weeks. thanks.
  10. stump_puller
    stump_puller 1/2 ton status
    Apr 5, 2002
    871
    135
    Corbin, Kentucky
    just go to any parts store. I got mine from advance auto. Didn't cost that much as I can remember. no sweat. I think there is a brown wire that is not needed. As far as I can remember it wasn't needed when I did mine.
  11. big d
    Oct 24, 2001
    1,236
    illinois
    did u have to get the heads off the donor vehicle also ? i read in another post here, that some people had to, so that the accessory brackets would bolt up correctly.please let me know. many thanks. /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  12. BayouBlazer88
    Jul 31, 2002
    353
    Lafayette, LA
    No, the heads are the same as far as the front mounting bolt holes go. So you don't need the heads from a donor vehicle, you can use your stock heads.
