Serpentine Conversion questions..
Discussion in 'The Garage' started by Confedneck79K30, Jan 27, 2007.
  1. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    so i got all the stuff from a newer sbc to go serp. on my 79/86/77 abortion...
    it has an a/c compressor, and i will not be running a/c... should i make a plate to cover the outlet and inlet holes and oil it and just run it? or should i get a shorter belt, and which belt should i get? any way to tell what year this setup is off of? i got it from a friend who it was given too off of a newer sbc...
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You could leave it in place and use it for onboard air, or buy an "a/c delete" pulley that takes its place. Blocking off the ports works just fine also, just to keep it from getting ruined, should you decide to use it later. :cool1:
  3. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    i figured to block it off so it didnt lock up and stayed lubed... you can use a factory gm ac compressor for oba?
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    It's not going to lock up on you if you don't block off the ports, it's freewheeling when the compressor is not engauged. All that will happen is in time it will basically make the compressor unusable for A/C.
    when i say freewheeling, i mean the clutch,, no power to the clutch, and it won't engauge the compressor.
    I'd still see about aquiring the A/C delete pully though in the future
  5. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    a/c delete pully and bracket. or killbyenterprises serp belt /york onboard air comp setup. i have a delete pully/bracket if needed. pm me.
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, a friend of mine has had an R4 style compressor for OBA on his TBI 350 powered CJ7 for 8-10 years. He just drips a few drops of oil into the intake side every once in a while.
  7. 4xcrazy
    Oct 31, 2003
    9,472
    5
    kinda of a useless point, as i mentioned previously, the compressor does not spin at all unless the pressure valve sends power to the compressor (switching on the ac) all that is going on is you are freewheeling the clutch, which there is nothing to oil.
    Hell, technically, i have been running mine like this for the past two years, as i haven't been able to get the ac working properly, and sort of gave up on it :crazy:
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Pay attention to the thread... :doah:
    He asked if it was OK to use the compressor for OBA. The answer is yes. You're the only one harping on when the compressor actually engages. :rolleyes:
  9. 4xcrazy
    Oct 31, 2003
    9,472
    5
    ok, ok, ok, my bad,,,why don't ya throw another :rolleyes: in there while your at it,,,,thanks for the "corteous" correction there big guy :rolleyes:
  10. sweetk30
    Nov 1, 2004
    25,552
    546
    this style bracket for a/c comp correct?
  11. 1-tonmudder
    1-tonmudder 1/2 ton status
    Apr 24, 2005
    3,052
    In a junkyard somewhere
    I am doing this same conv on my M1009,and the brackets I got left the alt on the PS.
  12. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    the Vortec brackets put the alternator on the passenger side
  13. 1-tonmudder
    Apr 24, 2005
    3,052
    Mine were from a 92 20 series van.
  14. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    yassir, thats the one... hell i got the alternator and p/s pump with it, and a new waterpump too lol
  15. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Just bear in mind that you can't 'mix and match' all the serp stuff. GMPP serp set up is way different to stock K5 serp stuff.....ask me how I know!:rolleyes:
  16. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    mines from a 98ish pickup...
