Serpentine Drive Brackets
Discussion in 'The Garage' started by biobry, Feb 9, 2005.
  1. biobry
    biobry Registered Member
    Dec 26, 2003
    76
    North Florida
    I picked up a set of the aluminum brackets to convert my 85 GMC to Serpentine belt. I bead blasted the brackets, and was thinking of spraying them with clear to help preserve the appearance...any thoughts on this?
    Bryan
  2. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
  3. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    i plan on converting to serpentine belts on my blazer. the motor is out of a 1990 blazer and has the v belts. what vehicles have the same accesory placement but use serpentine belts? im also ditching the a/c.
  4. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    any tbi truck with a 4.3 v6 or small block V8 would work. These brackets are all the same and when they don't have ac a idler pulley was just added where the compressor would normally be. S-10 blazers are a great source for these as long as the have the 4.3 engine.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    no serpentine setups have the same accessory setup. Alternator is on opposite side, same for the A/C, its just the way it is. Means a pain if you have A/C, need to have new lines made or get the lines from the donor vehicle. If no A/C its not hard to change. You need a new water pump as well, the V-Belt one is a standard flow but the serpentine is a reverse flow since the belt runs the other way across its pulley. Doesn't hurt to get a new water pump anyway. I haven't located a nice aluminum reverse flow but I haven't really looked either. Going rear radiator so more flow will be neccessary as well as a little bit lighter is always good.
