Serpintine switch
Discussion in 'The Garage' started by CaveBlazin, Apr 6, 2004.
  1. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Ok thinking of switching to the serpintine setup but what all will I need and what other things have to be done??
  2. thefarside
    thefarside 1/2 ton status
    Jun 27, 2003
    343
    Vernon, CT
    I am not sure if they still carry it but Summit had a kit to do this it came with the pulleys, brakets and other hardware.
  3. biobry
    biobry Registered Member
    Dec 26, 2003
    76
    North Florida
    I just picked up an entire serpentine setup at the local salvage yard that was from a totalled '97 Z71...included A/C Compressor, alternator, P/S pump, water pump, brackets and bolts...$250 out the door. If you can get lucky enough to catch a freshly wrecked truck coming in just buy everything on the front of the engine.
    Good luck!
    Bryan /forums/images/graemlins/k5.gif
  4. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Will I need the A/C compressor? I thought I could just change the belt wheels? Im kinda new at the serp change over stuff... /forums/images/graemlins/yikes.gif
  5. kazajames56
    kazajames56 Registered Member
    Jun 13, 2003
    28
    Kenner, LA
    I just did this a few weeks ago using everything from an 89 Suburban. Get all the brackets and accessories. I don't remember exactly, but I think the compressor bolts on differently than with the V-belt setup. You may need to cut the bracket by the fuel pump (if you have a mechanical one), because the empty spot for the smog stuff (?) gets in the way. I ran a new fuel line behind the bracket. Also, the thermostat housing may need to be changed; it may not let the existing hose clear the belt. You also need the water pump, because it turns in the opposite direction (as well as the fan). Hoses for the A/C compressor may be helpful, because they are shorter, but not completely neccesary.
    Hope this helps. My swap works great, definitely better than those V-belts that would never stop squealing no matter what. I can take pictures if you need them.
    Steven
  6. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Pics would be outstanding, if you can post them here but if not email them to harrissr@lejeune.usmc.mil
    Thanks /forums/images/graemlins/thumb.gif
  7. kazajames56
    Jun 13, 2003
    28
    Kenner, LA
    No problem on the pics... might be a few days because the Blazer is still in the shop, but I'll take down your e-mail and send them ASAP.
    Steven
  8. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    If you have the cash, check out Pace Performance on the web. I know they have a complete serpintine setup for a few hundred bucks and comes with everything you need.
  9. Nike
    Nike Registered Member
    93
    Jefferson City, Missouri
    I agree with going to the yard and getting everything off the front of the engine, including all pulleys. Do not forget the water pump, it drives off the back side of the belt and has a reverse flow impeller. Thanks Nike
