servicing 10 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89GAK5, Oct 2, 2000.
  1. 89GAK5
    89GAK5 Registered Member
    Sep 18, 2000
    22
    GEORGIA
    ok: i crawled under around and over the rear end looking for the plug to check the level.every thing that looks like a plug is welded.theres a round plug on the right side that has a square hole in it.i didn't go any futher.wanted to make sure first.thought it would be higher. this plug is about 1/2 way up on the side.i always had it checked when serviced.now that i have my on place in the country.im doing all the servicing that i can. somebody point this out for me. thanks
    RUGERS & K5 BOWTIES
  2. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    the plug with the square hole is the fill hole. just use a 3/8 ratchet to remove it, and your on your way.
