SES Light...
Discussion in '1983-2005 S-Series models' started by Drey, Aug 1, 2004.
  1. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    I got a 96 Blazer with the HighOutput 4.3 Vortec recently. I have installed all four new O2 sensors and also an EGR Vavle all of which the original equipment was bad. It performs significantly better...but I still get the SES light when I run it real hard for a mile or two, or when I roll it up around 75-80. It lose alot of power, and have almost no acceleration unless i have the pedal to the floorboard. Also shifting gets screwed up, I wont get second gear till like 35 then it kicks it in real hard and if on gravel it leaves scratch marks.
    Do you guys have any idea what it could be. Ive also had a friend reset my system with his OBD2 thing a few times and it works great till I run my Blazer hard enough to kick the SES light on.
  2. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Try the TPS or check the tranny module. Aw who am I kidding, I don't know crap about it. /forums/images/graemlins/screwy.gif
  3. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    the EGR passages might be plugged, but lets not guess, go get it scanned and post the code # for us
  4. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Well i finally took it in, and got it looked at, Fuel Pump wasnt puttin out enough PSI for the Vortec 4.3 runs way better and i can actually run it up to the 95 MPH cut out for the first time since ive owned it.:grin:
  5. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    I added a new mass air flow sensor, I think that was the problem all along :doah:
