Set of 4 mounted 265/75-16 MTs on 8 lug steels
Discussion in 'Tires | Wheels' started by BadDog, Apr 29, 2007.
  1. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I posted these in the regional earlier today. Local only, but maybe someone's passing your way? CO guys can check with Harley among others.
    Parts Page
  2. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    Russ,
    are these e rated? What's the size equivalent? If they aren't too big (i.e. under a 35) I am interested in them for my f350
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    The work out to roughly 31.5" IIRC. They are load range "D", which I think is as high as you'll find in a MT. FWIW, I've run "D" rated ATs on my 2500HD since it was new.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If they weren't an MT I would probably buy them. I also run a D rated BFG AT on my Dodge 2500 Cummins. They do fine unless you are towing alot. Matt (az-k5) works at Discount and says I am fine with a D rated tire. He said if I was towing 10K+ on a regular basis then I should probably have a E rated tire. I am only towing about 8K once a month so I am not concerned at all.
    Harley
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yep, that's pretty much my exact opinion on the matter, though that discussion typically turns somewhat religious in nature. ;)
