Set timing on an 85 ? And Story
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rockink5, Jun 8, 2003.
  1. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    Is there a trick to setting the timing on an 85 Blazer?I have searched the subject but can't find any info on mid 80's junk. It has a CC HEI and a CC quadrajet. Just finished putting new motor, carb, and all new sensors in the truck and it still runs like crap /forums/images/graemlins/angryfire.gif. Checked all vacuum lines, plug wires and electrical connections, and can't find anything loose or missing. It is missing at idle and starts to miss worse at around 2000rpm /forums/images/graemlins/confused.gif.
    Thought maybe a distributor problem, but my new one is not here yet.I know on the Camaro's there is a wire you need to disconnect first prior to setting the timing, but is it on the Blazers, and where would it be?
    Also thinking maybe ECM? Any help greatly appreciated, even maybe oppions on what is wrong.
    I am at my witts end. /forums/images/graemlins/1zhelp.gif
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I thought there was only a plug to find on FI 87+ models.... I'd try restabbing the distributor first, any other symptoms that its timing like backfiring or fireballs out the carb?
  3. rockink5
    Feb 6, 2002
    693
    Tracy, CA
    No fireballs, but at one point it did pop out the back about 4 or 5 times, then it stopped /forums/images/graemlins/confused.gif
  4. JustHorsinArownd
    JustHorsinArownd Registered Member
    Mar 20, 2003
    77
    Flagstaff, Az.
    Im with Bowtie, maybe try and TDC on number one and install the distributor in again.
  5. rockink5
    Feb 6, 2002
    693
    Tracy, CA
    Unfortunatly, I don't think it's going to be that easy. This has been an on going problem for years, it just has never been this bad. The whole new parts swap was brought about by this or a related symptom. It just seems to be really bad now with the new motor and carb.
