Setting Backlash
Discussion in 'The Garage' started by BowtieRed, Apr 2, 2003.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    OK- is it possible to set backlash without a dial indicator and just with marking compound? I don't need it 100% perfect, just close enough to last for 5-7000miles.
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    No, marking compound just shows your pinion depth.
  3. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Well, the backlash and the marking compound are two totally seperate things...
    Backlash would be the "play" or "slop" between the pinion gear and the ring gear. Which is adjusted by moving the ring gear/carrier in and out in relation to the pinion. What you use the marking compnd for is checking the pinion depth..also called "Checking The Pattern". So, I would say no, You should get a hold of a dial indicator to do it right. Not just the marking compund.
