Setting timing on 350 TBI?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Dec 10, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    On the TBI 350, which plugs do I have to unplug to set the base timing? Also, what should the base timing be? I was told it was around 8 BTDC, is that about right...thanks
    Chris
  2. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    The connector that needs to be disconnected to set timing is a black connector with a tan/black SINGLE wire, located outboard of the brake booster. Be sure to reconnect when done.
    The correct timing for a 350 TBI motor is 0 degrees...the computer adjusts timing during operation.
    /forums/images/graemlins/burb.gif
