setting up a 14bff
Discussion in 'The Garage' started by SUPER'BURB, Aug 16, 2006.
  1. SUPER'BURB
    SUPER'BURB 1/2 ton status
    Jan 9, 2005
    929
    Mountain House, Ca.
    I have heard that the 14bff is one of the easiest rears to set up, but it would be my first gear change so.......
    For somebody who is reasonably mechanicaly inclined how difficult is it to change the geares in a 14bff?
    Can it be done in the rig or should it be removed?
    How long should it take, any special tools and are there any write ups you guys know about?
    As always thanks for the direction guys:bow:.
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    134
    Gears aren't too difficult to set up, but you have to be careful. It really helps to have someone who has done them help you. Luckily, you have CK5 :D. Once you setup your gears and think you have it right, post pictures of your gear pattern here and myself or someone else on this site can tell you if it is good to go. You can do this with the axle under the truck. You will need a pair of calipers (to measure the shims), a dial caliper (to measure backlash) and an inch pound torque wrench. There is a writeup on how to setup gears here: http://www.pirate4x4.com/articles/tech/billavista/Gear_Setup
    Feel free to ask any more questions on here!
  3. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    If you have never done them before expect it to take a long time mabey even as long as two solid days, you will probably get furstrated along the way swear alot and then get back to it. 14bff are easy to setup and with all the proper tools you can do such even if its your first one. Make sure you have all the specs and read the article on Pirate and download Yukon gears catalog.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    dial or digital calipers, a dial INDICATOR with a magnetic base, and a torque wrench.
  5. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    It took me about 5 days every day after work to set mine up. Prolly a total of 10-12 actual work hours. The crush sleeve was the actual HARD part because it takes so much force to crush it. The pattern part is just trial and error and lots of pic posting. Everything is easy to adjust on a 14B but it's all time consuming. It was a good learning experience. I set up used 14B 4.11's so I wasn't as concerned about doing it wrong as if I would have been with a brand new set of 5.13's or something. Research a lot, and be prepared before you start.:wink1:
  6. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    I haven't set up gears in a 14bFF but I did do them in my 10bolt. This video I got helped alot and pointed me in the right direction. I recomend buying this and watching it so you know what you are getting yourself into before buying any parts or tools.
    Also you probably need access to a hydrolic press.
    You can set up gears with the axel still under the truck.
    Good luck!! :waytogo:
    EDIT: Also don't do what I did and fudge up the threads on the tip of the pinion shaft by banging on it with your BFH. I took it to 2 machine shops and they couldn't save the threads. So I had to throw $150 worth of ring and pinion gears in the trash.
  7. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    You dont HAVE to have a press but it is nice, I like using it for starting the crush sleeve and especially for pressing on bearings. Its really not difficult to do but if you are not a diligent person or dont have patients to get it right then dont bother because there is only a right way and a wrong way, no in between. I reccomend you read read read, the more you know..... It doesnt take long to do (unless your carrier is fubar'ed, but thats another story) just make sure you get the right tools. A tool that you will need to do this correctly but probably dont have is that inch pound torque wrench, you need a dial type one that ranges from about 0-75 in/lb. I bought a new snap on, from ebay, for $70 plus shipping. It was a smoking deal considering its a $350 torque wrench.
    I personally like to have axle out of the truck, it makes it a little easier to work on. and they come out so easy, a few bolts for the leafs, driveline, brakes, and your good to go. It saves me headache from climbing under the truck and you will have to multiple times, back and forth. I would read alot, then if you have any specific questions ask them on here and then go to town. And if you run into any snags along the way, ask again on here. Setting gears is not nearly as bad as many make it out to be, once you understand them they become terribly simple.
  8. SUPER'BURB
    Jan 9, 2005
    929
    Mountain House, Ca.
    what about a detroit?
    Thanks for the responses guys.
    I am also thinking about ordering a detroit to go in it.
    Would that cause any problems?
  9. K5er4Life
    Oct 16, 2002
    1,456
    Bellflower, Ca
    only if you hate traction....:D
