Setting up a D44 and 14 FF for swap
Discussion in 'The Garage' started by BozoWise, May 9, 2002.
  1. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Finally found an upgrade for my 1/2 ton gear and need to know what I should do to get these preped. Should I go in and replace joints and everything or just clean them up and change fluids. There is no mechanical problems with them now, but I didn't know if I should go ahead and replace seals or anything.
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    For the rear if the brakes are good and the seals not leaking just change the lube.
    the front I would replace the u-joints and since it apart repack the front bearings and change the lube.
  3. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    What kind of u-joints should I use in the front? Is there some nice upgrades for the d44 out there that you guys have used?
  4. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    I have been using Spicer u-joints, they have ben doing good for me.
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Use Spicer's! The p/n is 5-297x for the old ones and there are some new ones (that are rumered to be stronger) 5-760x I think.
  6. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Can I get these at napa, checker, or auto zone or should I oreder them?
  7. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
  8. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    I would recondition as much as possible, including axle gear oil seals. I had assumed mine to be in good condition, but found out otherwise when I did some underwater fourwheeling. When I got home, my differential was filled with gritty water. Took quite a bit of work to flush it all out!
  9. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    WOW they are proud of the CTM u joints ;-) Got the 14 FF under the 79 today and getting the 44 preped for transplant. Will have pics up soon.
