Several parts needed
Discussion in 'Parts & Trucks Wanted' started by steedalx, Jan 9, 2004.
  1. steedalx
    steedalx 1/2 ton status
    Dec 19, 2003
    142
    Chattanooga, TN
    1. Black door panals to fit a 71 jimmy. I think anything from 61-71 will work.
    2. Dana 44 3/4 ton spindles and a 3/4 ton rotor/hub assembly. I need to convert my front end to 8 lug. I would also need a 3/4 ton caliper support.
  2. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    do you want metal ones or the vinyl covered ones? I have some 72 truck ones.
    69k5
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    67-71 are metal flat style, some were vinyl material covered for Custom and CST package, 72 doors and panels and parts are one year only unique and are ABS one piece molded, and wont work on 67-71 doors, steedalx already knows that it sounds like
    hope that helps
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    that answers my question. thanks for the info. good to know b/c i was thinking about putting them on my blazer but i guess not. its a cst so it has the vinyl stuff.
    69k5 /forums/images/graemlins/thumb.gif
  5. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Might want to add a newer set of axleshafts to that list while you have it apart. The pre '73 D44's had a smaller axle shaft Ujoint than the later ones.
  6. steedalx
    Dec 19, 2003
    142
    Chattanooga, TN
    Thanks for the info. Would something like 30 splines work?
  7. kennyw
    Jun 9, 2002
    13,224
    94
    I believe all Dana 44 fronts are 30 spline inners. It was just the Ujoint size that changed in '73. Ask about it in the tech forums and you should be able to find someone who has done this before and can help a little more.
  8. steedalx
    Dec 19, 2003
    142
    Chattanooga, TN
    I also need a passanger side front fender in good shape for a 71 Jimmy
