severe clunking
Discussion in 'The Garage' started by chevyk5blazer666, Jul 10, 2005.
  1. chevyk5blazer666
    chevyk5blazer666 Registered Member
    Jul 6, 2005
    44
    N.J.
    ok hi its me again. when i waz at 7 11 i put in reverse and i herd a prity bad clunk and i put in drive just to see if would do it .it did. so i went home and i put 80-90 in the tranzfercase and that dident help and i replaced all of the u joints. i think it is the rear because i put it in nutral and i went under neath and moved the drive shaft and there is play in it . is this gonna mess up my gears or cause me any problums.?? its a 10 bolt
  2. royjones
    royjones Trucker upper Premium Member
    Jul 6, 2005
    629
    6
    somewhere close to ya
    777 hay man first take the 80-90 out of the transfer case or it will be junk soon then go to the rear pull the insp cover you will get some oil coming out so be ready then look inside an tell us what you see
  3. chevyk5blazer666
    Jul 6, 2005
    44
    N.J.
    i took the 80-90 out aready i just wanted to see if it waz that and i aready took the cover off and it looks normal no metal shavings a little durty but nothing out of broke or chiped
  4. royjones
    Jul 6, 2005
    629
    6
    OK then it might be in the pinon bearings have you ever took one of these rear ends apart .you are going to have toget in there be sure to watch for shims on each side of the ringgear or maby get another rear with the same gear as the front
  5. chevyk5blazer666
    Jul 6, 2005
    44
    N.J.
    im going to get 4:88 anyways so i gess it dont matter thanks
  6. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Could be bad motor mounts too......
    I've got a clunk like that going into reverse, but I've been too lazy to replace the mounts.
  7. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    I have had a wornout slip joint in the drive shaft cause the same sounds before. But I'm STILL driving on it :crazy: after 2 years :eek1:
    I don't recomend this, but I'm a cheeeeep b@$+erd :D
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Mine is either noew or rebuilt everything from the tranny back , and I still get a clunk once in awhile . Torque gets transmitted from tranny , to case , to rearend , each piece takes up a little slack , hence the clunk sometimes when everything is known good . Add a locker in the rear that works on torque , and adds even more .
