sf 14bolt??
Discussion in 'The Garage' started by jtl_77, Jun 30, 2005.
  1. jtl_77
    jtl_77 Registered Member
    Aug 30, 2004
    33
    ky
    I have done some searching and could'nt find my answer. I have a sf 14bolt 8-lug out of 82 c-2500 laying around. I was wondering if I could just buy some 6-lug axles for it or is there some length differences?? Any other problems with making a change like that?
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Pull the axleshafts out of that axle and measure it. Then call National Drivetrain. In the past they had the 6 lug axles for around $88ea... Not sure if there were any length differences throughout the years, but as long as your measurements match theirs you good.. :thumb:
  3. 4x4mike
    4x4mike Registered Member
    Mar 25, 2004
    16
    Sacramento, California
    The axle tube lengths on the K and C trucks differs. I have an axle from a 2wd drive truck and it is narrower than my old 10 bolts that I took out. The axle lengths may be the same.
  4. dyeager535
    26,982
    191
    Whats the WMS-WMS on that axle?
    There are apparently 3 different widths of 14SF, my 6 lugger is 68". If yours is that, then you know that there are stock axles out there that will work.
  5. sandracer799
    sandracer799 1/2 ton status
    Feb 10, 2004
    834
    Richmond,Virginia
    I got my shafts from a mid 90's truck with the 6 lug 14 sf and they were a little longer than what i had, i ended up have to space out the backing plates and it made the rear axle as wide as the front axle.
