sf 14bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Tree Hugger, Nov 16, 2002.
  1. Tree Hugger
    Tree Hugger Registered Member
    Oct 20, 2002
    9
    Kent,Wa U.S.
    I have the opportunity to have 1 for free and was wondering if it is worth the effort to change it over to 6 lug and use it or not?
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Would be neat if it would hold some of the newer 6-lug axles for the 14SF.
    If not, order up custom 6-lug copies of the originals, and convert to disc brakes.
  3. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    buy a set of 6 lug axles shafts and you're set. /forums/images/graemlins/thumb.gif
  4. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    You need 6 lug axles from a 88 or newer 4x4, they slip right in. 6 lug axles from an 88 or newer 2 wheel drive will not work, they are too short by about 1.5 inches. I know this from experience.
  5. u2slow
    May 9, 2001
    2,217
    BC Canada
    Is that first-hand experience!? What did you do for brakes?
    I was wondering WTF the do with the 8-lug 14SF in my Burb when drop in the FF. /forums/images/graemlins/grin.gif
  6. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    Yup .. Vic has it right. You want the shafts from a 4x4, the 2wd versions are not the same. I used shafts from a '93 4x4 and converted to disk. Alternatively, you could always "fill and drill" the 8 luggers to 6 lug, then either convert to disk or do the same with the drums.
  7. RedBrute
    Sep 22, 2002
    346
    As a side note, I got a quote from Moser Axles to do the machine work to turn my 8 luggers into 6 luggers, plug 8 holes turn flange OD down to 7.5" redrill 6 holes and turn center hub down to 3" came to $120/pair. Shipping was pretty steep though, $140 so I decided to go 8 lug.
