SF VS. FF in 14bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by StiffRide81, Sep 18, 2002.
  1. StiffRide81
    StiffRide81 Registered Member
    Aug 24, 2002
    53
    Tinley Park, IL
    Hey, what is the difference between semi-float and full-float??? Besides the words thems selves. I know full is better... buy why... and what do they do??? (difference)??? /forums/images/icons/confused.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> The basic gist is that in a full floater, the axleshaft's only job is to spin the wheels. The actual weight of the truck is supported by a spindle and a hub, essentially the same as on a front axle. On a semifloater the axleshaft turns the wheel, but the weight of the vehicle also is supported by the shaft via a bearing on the end of the housing. A happy side effect of the fullfloater design is that if you break an axleshaft the wheel stays on, but that is not the main point of the design, the point of the design is increased load carrying capacity. For us that means mucho strength for wheelin. Always a good thing. /forums/images/icons/grin.gif </font color>
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    The FF axles bolt onto the hub on the end of the housing so iff the axle breaks you can still limp off the trail.
    The SF uses the c-clip like a 10 bolt. If you break an axle, there is nothing to hold it in the housing and it will just walk itself out.
    The SF is better than a 10 bolt because the shafts themselves are larger.
  4. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    Also, the SF is 6 lug and the FF is 8 lug which means that you would have to change your front end to 8 lugs also if you install the FF, unless you want to drive around with 2 different spares. If you want to install the SF you will have to move the spring perches. i am thinking about doing the SF because I don't want to buy new rims and spend money on changing the front end also and I feel a SF is plenty strong for what I need. If you plan on doing some really hard core wheeling it's not that big a deal carryingan extra axle shaft.
  5. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    The semifloating version also comes in 8 lug.
  6. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    They started making the SF 14 blt. in 81(?) in the 8 lug version and started using the 6 lug version in 88-up light duty 3/4 tons and some Z71s. I believe they also used a 5 lug version in the 454 SS trucks.
  7. bajaviking
    Apr 10, 2002
    752
    Baja
    You are right but my point was to suggest a SF 6 lug to not have to mess with changing the front to 8 lugs, I think that if somebody wants an 8 lug they would go for the FF and not a SF.
  8. BIG STEVE
    BIG STEVE Registered Member
    Jul 23, 2002
    66
    thornton colorado
    Put a sf 14 in my 90 jimmy 15 inch wheels bolt right up
    14 mm studs back 7/16 front got some extra lug nuts now. /forums/images/icons/shocked.gif
  9. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    DON'T LET THEM FOOL YOU!!! SFs are way cooler!! all the cool guys have them (me /forums/images/icons/grin.gif ) and they have better ground clearance.
    seriously though, there ain't a thing wrong with a SF, my suburban's semi floating 14 bolt has 156,000 mi on it and it's been jumped 3-4 times with a full load of people and it's just fine. /forums/images/icons/smile.gif
  10. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    In matter of fact, 12 bolts are better. They have even more ground clearance than a 14sf. /forums/images/icons/ooo.gif /forums/images/icons/ooo.gif /forums/images/icons/ooo.gif
  11. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Yeah 14SF are kewl! They support ARB air-lockers... ask me how I know!
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    Nah...Dana 30 axles are the best!! /forums/images/icons/tongue.gif /forums/images/icons/laugh.gif
  13. muddysub
    Jun 23, 2001
    10,452
    489
    [/ QUOTE ] BAHAHAHAHA!! /forums/images/icons/laugh.gif /forums/images/icons/laugh.gif a loaded suburban jumping 5' off the groung would snap a 12 bolt like a toothpick.
  14. StiffRide81
    Aug 24, 2002
    53
    Tinley Park, IL
    YA... sorry man.. but NOOOO.
    12 bolts arent better. I have been into drag racing a LONG time.. and 12 bolt are pretty strong.. but not THAT strong.. and The ground clearance thing... what a 1/2 inch?? Big deal.. get one size tire bigger... there you go.
  15. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    First of all, the 14 FF and 14 SF are completely different axles. The SF has a 9.5" ring gear and 33 spline semi-floating axleshafts...basically a 10-bolt on steroids and overall a relatively strong axle.
    On the other hand, the 14FF is just bigger all around with a 10.5" ring gear, bigger housing, bigger axle shafts, and of course the full-floater design.
    Since the FF design requires the shafts to only transmit torque, there is less overall stress on the shaft and therefore a shaft of the same size will be "stronger" than if used on the SF design.
    The most common 14 SF axles were found in 3/4 ton Chevy/GMC trucks and Suburbans starting in the early '80's and were 8-lug. Based on what I have seen the 14SF is much more common in these trucks than the 14FF. The 6-lug 14SF only came about in '88 under some of the light duty 2500 (3/4 ton) trucks when they switched to the new design with IFS, while a few select 1/2 ton models with certain towing packages also received the 6-lug SF. It seems as if the 6-lug version of the 14SF was sort of phased out of use in 2500 series trucks because I haven't seen any on lots or any newer modes on the road with 6-lugs for quite some time. I have not seen a 6-lug 2500 truck newer than maybe '95 (when they changed the dash design).
