SFA Conversion Question
Discussion in 'The Garage' started by Swanson52, Feb 18, 2003.
  1. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    I am thinking about buying a 92-or-so GMC 4x4 from my uncle, and of course the first order of business is getting rid of the IFS. My question pretains to the front axle. CAN a GM 60 front be used if I have a passenger drop tcase? The automatic in the truck is toast, but I have a 700/205 (passenger drop) and can get my hands on a GM or a Dodge 60 much more easily than a Ford. What are the issues involved here, or should I just sell the passenger 60 and get a HP Ford?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Change the case and it's not really a problem, other than the issues related to doing the tranny/case swap itself. No other real issues that I know of. I've seen it done on more than one truck so I know that it's possible. </font color>
  3. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    You will have to get a new computer for the truck that either came from a similar truck but with a manual tranny or one with all the tranny stuff programmed out of it. If you just swap a non computer controlled tranny in the computer will start going nuts. Also have to adapt the VSS. Other than that the solid axle swap part is easy /forums/images/graemlins/smile.gif.
  4. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    The only thing I should run into there is the Tcase lever, no? I should clarify, the trans is actually a 4L60 out of a 91 GMC, so it's the right trans for the truck, just have to work out the tcase issues?
  5. tonto
    tonto Registered Member
    Feb 12, 2002
    50
    oklahoma
    Could have the transfer case modified to accept a vss. The same as what Steve had done on his blazer when he swapped in a doubler. Did a search and found the post, included the guy who did it and his number. Donovan Horton ,303-423-6152. He modifies the output houshing to accept a tone ring. Hope this helps, if you talk to him let me know. Interested in this myself.
  6. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    On off-road.com there was a member on the bbs named Mike Blake (90extcabon40's) with a GM 10 bolt up front and he swapped in an NP205. He made a post about all the work he did to get the shift lever to go through the factory floor hole in his 1990. Had a pick of his linkages too. He hasn't been around on there for over a year now but you can search the IFS forum for the post...
