SFA Swap and Crossover
Discussion in 'OffRoad Design' started by willyswanter, Oct 26, 2001.
  1. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I'm getting ready to do a Dana 60 swap on my 96 crew cab long bed 1 ton chevy 4x4 and want to go with the ORD xover steering setup. Will the kit work for my app. or do I need a custom job? I can bend my own xover tube so thats not too big of deal. Will the steering arm work on the Ford mid 90's dana 60 front?
    [​IMG]smile[​IMG]
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Our arm works on any of the kingpin D60's. Depending on when in the 90's yours was made it may be ball joint. I think they stopped kingpins around '93? If it's kingpin, you're set. Use our steering arm and pitman arm and build the draglink to fit.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Our arm works on any of the kingpin D60's. Depending on when in the 90's yours was made it may be ball joint. I think they stopped kingpins around '93? If it's kingpin, you're set. Use our steering arm and pitman arm and build the draglink to fit. If it's ball joint, I don't know what to tell you. Probably call dynatrac, gulp. I know they do knuckle work to do a crossover on a ball joint D60.
    SW-ORD
