SFA swap/wheel size question
Discussion in 'The Garage' started by thezentree, Oct 14, 2003.
  1. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    im doin an SFA conversion on my 97 yukon, using a D60HP out of a '79 F350, and a 14BFF rear end (another question on that in a sec). can i run 15" wheels on these axles without griding the calipers or drums? or do i need to run 16"?
    also, what years should i be looking for for the rear end? i heard that the older 1 tons (pre-'88) have narrower rear ends. /forums/images/graemlins/burb.gif
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    The huge dual piston calipers on the ford front are close on my 16.5's so I can't imagine them fitting 15's without grinding...
  3. thezentree
    Sep 19, 2003
    7,198
    NC
    lol, crap. 15" wheels are cheap....
    did you grind your brakes at all?
  4. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Sorry, I run 16.5" double beadlocks /forums/images/graemlins/wink.gif
  5. Masher
    Masher 1/2 ton status
    Mar 7, 2002
    123
    SW Michigan
    I just got done doing the same setup under my '96 Z-71. I ended up getting different caliper brackets for the HP 60 from JB's 4x4 that allow you to use 3/4 ton Chevy calipers and rotors. I also have discs on the 14FF and the truck stops better now with 40's on it than it did with the stock brakes and 35's. /forums/images/graemlins/thumb.gif I did have to grind very little on all calipers to get the 15" rims to fit, and I do mean very little.
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yeah same ont the HUGE dual piston calipers, the 16.5s barley fit, 15s wouldnt.
