Shackel flip, who all is running it ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Z3PR, May 5, 2002.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Who's running a shackel flip, and how's it been working for you ??? Any problems with it ???? How's it on the streets ???? Any concerns about it ????
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    me! good! none! good! no!
    think that covers it. /forums/images/icons/tongue.gif
    J
  3. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    me! good! none! good! no! too!
    rob
  4. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    Same here
  5. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    me! great! nope! street???? I did a custom one and the shackle angle is wrong, I worry a little about the springs inverting on compression. Other than that, NO. ORD makes an awesome product. I'll be doing something similar soon.
  6. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
  7. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    Towed a 6500# trailer from GA to MT. No problems. Even when I hit a snow storm and ice. I did loose it for a moment, but I don't think it was because of the flip. Others where in the ditch also. I did remove my bottom leaf from the stock springs and put in a add a leaf overload spring. Which in turn gave me another 2" of lift and some stiffnes. Flex is still good! I recenlty RTI on a 20% ramp and scored a 702.
  8. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    well, it works great sitting on my work bench/forums/images/icons/crazy.gif
  9. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Mine works fine...
    Jim
  10. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    Add my name to the list of all of the above. On my second vehicle with it. Two friends are running them too. Both with good results. Having done both a pickup and a Suburban, I must say, I'd rather do it on a pickup than a Blazer or Suburban again. (Or at least remember to run the 40 gal tank a little lower on fuel /forums/images/icons/tongue.gif) The spare tire well on a Burb is kinda a PIA too.
  11. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    I. I also tow my Jet skiis no problem
  12. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    Mine are on the bench to but the welds are fanatic you can see the time is spent making it /forums/images/icons/smile.gif
  13. Erich_in_AZ
    Erich_in_AZ 1/2 ton status
    Mar 23, 2002
    237
    Tucson (it\'s a Dry heat), AZ
    I cheated and did the "poor man flip" for now. I have talked to several people that have done it this way and it seems to work fairly well. I still have some reinforcing and extra clearancing to do around the shackle. Eventually I am looking at coilovers or 1/4 eliptical, so this will have to do for now.
    Pics should be up in a few minutes.
    http://community.webshots.com/user/erich_in_az/1
  14. mudrunner78
    mudrunner78 1/2 ton status
    Sep 7, 2001
    366
    Rocksprings, TX
  15. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I use the ORD 4'' flip and it stands up to me jumping my K5 all the time. No problems here, but I still need to replace my rear springs.
  16. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I've run the poor mans cut through and built my own. I like the ride of both, on and off the road. Its a bit softer at speed and I noticed a slight change in the rear end sway characteristics on the road around corners. Pics in the signature.
