shackel flip ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wayne, Apr 11, 2001.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    As most may know I am getting ready to do a lift and rear swap. ? is with the rear flip do you still need to shim the rear for correct driveshaft angel. My thought on this is if you drop the back of the spring 4 inches it will give you a couple of degrees on the angel. Thanks.
    <A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
    <font color=blue>Happy Trails<font color=blue>
    <font color=blue>Wayne<font color=blue>
  2. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    No you do not. If your going with stock rear springs then the angle that the shackle flip provides is just right. I've got zero vibrations on mine after the shackle flip and that is with NO shims.
  3. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Waxer is right. It was the same way on my truck. No vibs or any other problems.
    '73 K5
    Chevy good...Ford bad
  4. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    And you can thank Steve for that when he cleverly designed them!! The angle works out perfect when you use his shackle flip!
