Shackel Flip
Discussion in 'The Garage' started by SUPER'BURB, Feb 14, 2005.
  1. SUPER'BURB
    SUPER'BURB 1/2 ton status
    Jan 9, 2005
    929
    Mountain House, Ca.
    Hey,
    I was woundering if anybody has done an ORD 4" Shackel Flip with a 2" lift spring. What I am woundering is does it sit level with a 6" front. I have a 14 bolt rear and a D44 front on my '73 'Burb. I was also woundering if any pinion angle problems arose in the rear. I have already orderd the kit from ORD but have not yet orderd the springs and lift kit.
    Any info. and/or pics. would be great.
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I'm sure someone has done it, shouldn't be a problem.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I doubt it will sit level with a 6" front lift and 6" rear lift. You will probably want to order a 3" or 4" rear lift spring to get it to sit level.
    Harley
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    6" springs front, 4" shackle flip + 3" springs.
  5. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    There's a thread by Desert Rat in the ORD forum about this very thing. Short answer: 4" flip + 2" spring does NOT equal a 6" front spring. :D
    -- A
  6. sweetk30
    Nov 1, 2004
    25,539
    539
    horseheads , ny 14845
    blazers and burbans sag lift the back at least 1" over what you want. i did a friends blazer and put 4" frt and 6" kit blocks in rear. that looks about correct for the ride . he has 3" body also and now rides on 37" pro comps xt.
  7. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I used the 4" ORD shackle flip in the rear w/ zero rates. It does not eaven out the 5" lift springs on the front. I'm going to change out the rear springs someday.
  8. SUPER'BURB
    Jan 9, 2005
    929
    Mountain House, Ca.
    Thanks for the info. it is very helpful.
    I guess my qestion now is do I get a 3" rear spring or a 4" rear spring?
    CBBR how much mor lift do you need to be level??????????
  9. folkenheath
    folkenheath Worthless Trash Premium Member GMOTM Winner
    Nov 12, 2004
    4,269
    159
    Wisconsin
    I would say call ORD and ask them, they build a suburban as well, so they should know if you need a 3" or a 4" leaf in the back to match your front. I used 2" springs in the back of mine, and it worked, but I have a shortbed truck. I think with a K5 the 3" would work better, but a burb might need a 4" with the shackle flip. Good luck. :)
  10. SUPER'BURB
    Jan 9, 2005
    929
    Mountain House, Ca.
    Thanx,
    On the phone with ORD soon will let U know what they say.
    Will also get pics. up.
  11. cbbr
    Jul 17, 2004
    14,681
    I'm going to go with a 2" lift spring and the zero rate. About 2" should even it up.
  12. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,959
    250
    Released from Pueblo, told I belong in Southpark
    I went with 6 inch front spring, 4 inch shackle flip and 3 inch spring and if it is still lower than I like I figure I can do a zero rate. Cant tell how its going to work since all the stuff is in a pile in the garage. :(
  13. cbbr
    Jul 17, 2004
    14,681
    sounds about right. My stock springs sagged a little bit and the front, while advertised as 5" gave me a little more than 6" of lift.
