Shackel Flip ?
Discussion in 'The Garage' started by blazin_, Jan 13, 2007.
  1. blazin_
    blazin_ Registered Member
    Nov 20, 2006
    14
    Mesa, Az
    I've just started my research on this, and thought to ask here. What do you guys think about a shackel flip on a stock 87 Blazer ? Of course my intentions are to get some lift and to be able to put on larger tires. This is my DD so hows it gonna ride ? What tools/tips and tricks might I need to know ? Can a closet machanic/weekend warrior get it done in a weekend ? If anyone has any suggestions, or knows of some articals I can read please reply. :usaflag:
  2. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
  5. AKbigsub
    AKbigsub 1/2 ton status Premium Member
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    I got mine from DIY4X :D
  6. Steve GMC
    Steve GMC 1/2 ton status
    Dec 3, 2005
    247
    middletown,Connecticut
    i've herd great reviews on ord. so thats waht i got
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The truck won't ride any different than it does now. A novice with minimal skills can get the job done in a day if you're prepared correctly. The first thing you need to know is that the gas tank needs to be removed so obviously having close to an empty tank of fuel when you start is a big plus. You will be removing a bunch of rivets so you'll need either a drill and proper size drill bits, a torch, or an air chisel. This takes the longest but with the proper tools should only take a couple hours. You will also need a good jack and jackstands. Also needed will be the proper size wrenchs and sockets for bolting the flip on.
  8. sweetk30
    Nov 1, 2004
    25,552
    545
    horseheads , ny 14845
    also pry to the bolt gods that the spring eye bolts are not frozen in the spring bushings. :haha:
  9. 54inches
    54inches 1/2 ton status
    Feb 9, 2004
    1,535
    Houston, Texas
    Shackle
    ORD one is great!
