Shackle angle with Diy4X4 shackle flip?
Discussion in 'The Garage' started by K5Glazier, Feb 21, 2006.
  1. K5Glazier
    K5Glazier 1/2 ton status
    May 29, 2003
    220
    Chandler, Az.
    Did a search, but didn't find what I was looking for. I did the shackle flip using the stock 52" springs. Looking at it from the side, it looks to be in the 6:30 (clock) position. Have not mounted the tires on yet b/c I have alot of work to do. Once I mount the tires, will the angle change?
    What angle do you guys have with the same set-up? Should I do the 56" spring swap?
    Thanks,
    Joe
    sorry no pics, truck is 100 miles away and I forgot the memory chip for my camera:doah:
  2. 1-ton
    Apr 17, 2004
    2,889
    166
    Las Vegas, Nevada
    Your shackle angle sounds correct to me. My DIY4X shackles are in the same position, with 52" springs. The shackle angle will change only a very little as you put weight on the springs. If you go with 56" springs, you will have to swap the shackle flip spring hangers to the other sides of the frame.
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Is their weight on the spring/shackle? I would think unloaded the shackle should be pretty close to vertical, but with weight on it it should be more like at the 5 o clock position (optimal). Like this \ with weight on it. if it is like this / with weight on it you may have them on the wrong sides.
  4. 1-ton
    Apr 17, 2004
    2,889
    166
    Las Vegas, Nevada
    Here is a picture of mine with 52" springs, and the full wieght of my truck on it.
  5. K5Glazier
    May 29, 2003
    220
    Chandler, Az.
    Seems I have installed them correctly. Now I'll toy with the 56" spring idea.
    Thanks guys,
    Joe
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Here is what mine looks like with the brackets flipped around and 56s with a 6" shackle.
    Ira
  7. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yeah you were talking looking at the pass side and i was thinking driver side. I thought about that after I replied LOL. They should be around 35 degrees I believe is optimal.
