Shackle angle?
Discussion in 'The Garage' started by crwln73, Dec 29, 2002.
  1. crwln73
    crwln73 1/2 ton status
    Sep 6, 2002
    362
    Clovis,Ca
    Is this too much??Do I need longer shackles? Shackle [image]http://coloradok5.com/photos/showphoto.php?photo=2967[/image]
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    How is that set up? Is that the ORD kit?
  3. muscle
    muscle 1/2 ton status
    May 28, 2000
    408
    Show Low, AZ
    I'd say you need something. There is no travel left in those shackles.
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> The springs look nearly flat, so long as the shackles don't max out when the springs are completely flat then you'll be fine. I'd suggest just jacking up one side of the axle to get one spring flat so you can see if the shackle maxes out. </font color>
  5. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I'd say you have a bit too much angle...but like Shaggy said as long as the shackle doesn't hit anything when the springs are flat you should be OK. Yours look like the shackle would be near flat when the spring is flat and might go over center.
    It is hard to say for sure from a single picture though...
    rene
  6. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Well it probably wouldnt hurt to build a set of dogleg shackles just so it doesnt hit, im gonna have to do that with mine too. Id be afraid of breaking a main leaf.
  7. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    dogleg shackles
    [/ QUOTE ] Could he just turn his over? Or am I just a dumbass.... /forums/images/graemlins/crazy.gif
  8. ben427
    Mar 10, 2002
    1,123
    Not with a factory shackle, because that would actually make a better chance for the shackle to hit the spring from the dessign of the shacle.
  9. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Yes, your shackle will bottom out the first big dip you hit. Your not even resting on the overload yet. If your truck was set up for 52" springs and you reversed your ORD brackets then your back and inch at 53". Your shackle is 4" so the two together when the springs lay flat will go completely horizontal at 57" (the length of those packs flat) and then impact. Adding just an inch to the shackle would bring you close to eliminating this and 1 1/2" more and you would clear it.
