shackle bind...pics
Discussion in 'The Garage' started by HELLBENT DESIGNS, Jul 17, 2005.
  1. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    got a question for you shackle flip guys. i did a shackle flip with stock 2wd hangers swapped in for the rears. i currently have the stock rear shackles in. when i push down on the rear frame the shackle moves back and gets caught on the inner part of the hanger. i could cut the hanger for clearance. extend the shackle a bit? i pretty much have the lift i need but an inch more lift wouldn't hurt! what about another type shackle :dunno: thanks!
  2. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    DIY4x.com or ORD? :wink1:
  3. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    the shackle flips they sell kick a$$ but not an option! the rear springs i are 64's with 5-1/2 inches of lift. the way i have it set up is basicly a no lift flip!
  4. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    You need longer shackles and a little less shackle angle. I'd aim for about a 20 degree shackle angle with a shackle 2" longer than what you have now.
    Rene
  5. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    could you rotate the hanger ccw in reference to the pic to avoid the interference. unfortunately, you already have holes drilled and that support bracket fabbed as well. good luck
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    as rene said, you need to change the shackle angle, or get longer shackles, or both.
    its bad to have the shackle like that. the spring can't extend any more, so it will try to bend the leave if enough force is on it. rotating is up or cutting for more clearance will make it worce as it will start going back forward making the spring shorter.
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Move the hanger back towards the rear untill the shackle is almost straight up with the suspension under normal load. Whan you flex, the shackle will move rearward before moving up. Do not take anything from the shackle IMO that piece needs more beef already, don't make it weaker.
  8. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    when i first did the flip i had the mounts about 2 inches rearward, at that time shackle angle wasn't enough! maybe it was correct after all the weight has been added :dunno: i previously had a tension shackle set up but it's all been a guess as far as ride height and how far forward or rearward to put the mounts. i will give the old mount spot a shot and it might be about right :confused:
  9. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    With that long of a spring, esspecially since they are soft lift springs, I would get a longer shackle to get all the travel out of them.
    Blake
  10. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    One thing that may help a little bit is to take the shackle out, twist it 180 degrees, and put it back in (you will have the "hollow" part of the shackle facing forward instead of backward), but I doubt it will completely solve the problem. The best thing would be to get longer shackles.
  11. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Here's some pics of me 64's. They are stock height springs with a 3" lift shackle. I think the shackle angle is ok now and will be just about perfect when I add the gas tank and spare tire to the back.
  12. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    I can't see your pics but I think I understand how you have the rig set up.
    What shackle angle do you have now? Is it close to the 45 degrees that most people recomend?
    If it is than I woulden't move the hanger anymore. If you do move it rearward you stand the chance of inversing the shackle and bending a spring...no fun :doah: (you might do that anyway without a limiting strap depending on how soft your springs are) If you cut the top of the bracket to keep it from binding you could also have the spring move so far forward that it cams-over and does't return.
    First thing I would do if you haven't already is set your bumpstops to ware you want them. Then determine ware the shackle side spring eye will be when it is fully extended....witch will be eather when the spring is flat or when you reach the bumpstop, witchever comes first. If at that point your shackle is going to bind then you should determine how long of a shackle you need to keep it from binding. If you stick with the 45 degree static angle then you probubly won't inverse the shackle when at full droop...if you do then you need to look at adding limiting straps...
    If you need some extra chevy rear shackles to try and lengthin let me know...I have a couple of extra sets out back you can have.
  13. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    It sounds like you need longer shackles first, and then go from there. I wouldn't worry about moving the hangers until you've tried longer shackles. Since you're using the stock-style shackles, you could probably pick up a pair of those lowering shackles the 2wd guys use. I think they're about 6" long.
    Best of luck, man :)
  14. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    yeah i am going to try the 2" longer style drop shackles for starters! not sweating it just another thing to deal with :D
  15. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    I have NO idea what you're talking about.... :haha: :doah:
