shackle bolts
Discussion in 'OffRoad Design' started by BOWTIE, Nov 13, 2001.
  1. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    Have any of you guys cut the bolt that sticks out of the nut once it's installed? After I installed these it seems that I'm gonna have to cut the remainder of the bolt to have some clearance. Check out the picture maybe it will explain it better.http://community.webshots.com/photo/24927226/25207623QrCDvCBVzA
    I know that these bolts are hollow, but does is it hollow where the tread is at?
    Ric
    <font color=red>Wheel hard or go home.</font color=red>
    <a target="_blank" href=http://community.webshots.com/user/bowtie1ton>MY K5</a>
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    bolt &lt;---- Clicky.
    I think it would be safe to cut it off there flush with the nut.
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
  3. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    The grease hole stops about half way through so that should not be a problem. I would loctite a new crimp nut though. I would do that because there is very little thread left before the nut would fall off if it came loose. The loctite is just a little extra insurance and yes I had a front nut fall off from the front spring hanger bolt once.
  4. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    You can cut it off, no problem. You'll want to leave about 1 thread outside of the nut, and the loctite isn't a bad idea, just a little extra insurance.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
