Shackle Flip 4" lift and towing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tch777, Sep 24, 2005.
  1. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    So I am looking at my lift options.
    The sub is mostly a daily driver and then the family travel vehicle for trips and camping.
    We might tow a trailer with 2 quads on it but that is about it.
    If I do a shackle flip in the rear and 4 inch lift springs in the front, keep the rear anti sway bar could I tow those loads and haul all the weight of the family and gear without issues and sagging?
    Oh yeah I will go to 35 inch tall tires too.
    Tim
  2. tch777
    Jan 15, 2003
    244
    Nobody has a Shackle flip and tows? :dunno:
  3. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    yep i do....have been towin for a few years now...i tow a 1800 pound trailerwith my blazer..soft springs and a flip in the rear...as long as you drive the vehicle accordingly in relation to vehicle mods youll be fine....
  4. snoman87
    snoman87 Registered Member
    Aug 25, 2004
    88
    Edmonton, Canada
    I would upgrade the shackle to something with a little beaf to it, like ORD shackles, to prevent bending under the weight.
  5. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    I don't have real world experience, so I can't give you advise, but if you search this has been discussed many times at great lengths with very strong opinions. I researched it while planning my build up a few months ago. There's no shortage of info, so go and learn. I'm not being a H.A., if I had my own experience I share it.
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I run 35's and a shackle flip on my Burb. I have towed a variety of boats, my big a$$ military (M105) trailer loaded down with stuff and a 18' yard trailer with no problems.
    The only problem i have ever had was because I had a load of flagstone in the M105 that was loaded too far to the rear. The trailer wagged the burb over 45 mph. That was my fault, not the flips.
    As long as you don't get in a hurry and don't try to tow huge loads, I don't see a problem.
  7. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Or use the http://www.diy4x.com/suspension.htm flip, you can make your shackles as HD as you want.
