shackle flip and 0 rates or new rear springs?
Discussion in 'The Garage' started by chris672, Aug 12, 2002.
  1. chris672
    chris672 1/2 ton status
    Jan 25, 2002
    554
    LODI, CA
    Right now I have a 4" suspension lift with blocks in the rear and a 1" body lift. I want to get rid of the rear blocks and I was considering either doing a shackle flip and 0 rates or 4" lift springs. I was wondering if anyone had some suggestions or opinions on what the best setup would be.
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Keep in mind if you go with springpacks 4" may not level your K5. Saggy butt! Reson is that premade springpacks are made to the pickup weight specs not blazer's. I used 5 1/2" Superlift packs in the rear of mine and sits level with the hardtop on & 4" Rancho up front.With the top off you can barly see the rear poking up a bit higher. I would rather have a little stinkbug than a saggy butt!!
    I never ran a shakel flip so can't give my opinion on that.
    Good Luck
  3. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i would go with the flip and zeros you'll flex better cuz the stock springs are flatter than lifted springs.
  4. muddysub
    Jun 23, 2001
    10,451
    489
    there's nothing wrong with the saggy butt! mine sags a little and i like it. but when i get the flip and zeros i'm gonna go up to 6" fronts.
