Shackle Flip and Front 4" springs
Discussion in 'OffRoad Design' started by 80K5, Jul 12, 2001.
  1. 80K5
    80K5 1/2 ton status
    Jun 5, 2001
    100
    Shackle Flip and Front 4\" springs
    I am planing to go with a 4" lift. Shackle flip in rear and 4" springs up front. I was just wondering what are the most common things that need to be done to the driveshafts with a 4" lift. I will eventually go with a cv shaft but I currently don't have the dollars to do it.
    Thanks for the help!
    Stuck? Isn't that a bird!
    Steve
  2. 80K5
    80K5 1/2 ton status
    Jun 5, 2001
    100
    Re: Shackle Flip and Front 4\" springs
    when did blazers start comeing with the rear springs with teflon.
    Thanks again!
    Steve
  3. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
    1987-1991 were the teflon years I belive.
    <font color=purple>L8R...</font color=purple>
    <font color=green>chevy4x4
    </font color=green>
  4. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    With a 4" you should be able to use your stock shafts. I'd definitely check the engagement, but you should be fine. Depending on your gears and tires, you may be able to get away without a CV for a while. Lower numeric gears with larger tires keep the driveshaft speed down to help with vibration.
    You should plan on dropping the t-case an inch or so, and then invest in an angle finder to measure and match up the angles. With the flip and a non-cv shaft, you'll most likely need to shim the pinion down a little. Probably 2-3 degrees, just as a guess.
    Best way to go is save up for the CV asap, it makes life lots easier in these.
    I've seen teflon pads as far back as '82, so it might be from '81 up.
    Making the world better, one truck at a time.
    [image][/image]
    SW-ORD
  5. 80K5
    80K5 1/2 ton status
    Jun 5, 2001
    100
    Thanks that cleared up allot.
    Steve
