Shackle flip and "right side up" U bolt kit for C2500
Discussion in 'OffRoad Design' started by SubYuman, Oct 4, 2004.
  1. SubYuman
    SubYuman 1/2 ton status
    Oct 13, 2001
    246
    Edwards AFB, Ca
    Shackle flip and \"right side up\" U bolt kit for C2500
    Will an ORD flip and bolt swap fit my C2500 with a 14b ff?
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Re: Shackle flip and \"right side up\" U bolt kit for C2500
    The ubolt flip will but the shackle flip kit will be a bit different. The offset from the frame will work and I think the bolt pattern will be the same but the height of the bracket for the 4wd is more than a 2wd. GM used the brackets to give the 4wds more lift so you will get more than a 4" lift from the 4" shackle flip kit. Otherwise, you're set.
  3. SubYuman
    Oct 13, 2001
    246
    Edwards AFB, Ca
    It still sits about 1.5-2" lower with the 4" block anyway. What are we talking about as far as the difference? 5-6" instead of 4"?
  4. SubYuman
    Oct 13, 2001
    246
    Edwards AFB, Ca
    Or....
    If someone was doing a swap, could I use their old brackets for few more "s? Cheao lift is ALWAYS a good thing!!
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    It should be a couple inches, so it might be what you're looking for.
    You might be able to swap the entire bracket set from a 4wd of similar year to lift it like a 4wd.
  6. SubYuman
    Oct 13, 2001
    246
    Edwards AFB, Ca
    SOrry 'bout the double up!!!
    Just trying to get some ideas on price and availablitiy...
