shackle flip and towing
Discussion in 'The Garage' started by Mudlug, Apr 20, 2004.
  1. Mudlug
    Mudlug Registered Member
    Oct 3, 2002
    5
    San anontio TX
    I need info from people that have ORD shackle flips
    I have a 95 Z71 and I am upgrading to a 14 bolt SF
    I also want to upgrade my rear spring set up
    I have a add a leaf block comb
    which would be better for a truck at is a DD a little offroad and some towing (my k20)
    6" lift springs
    or ORD flip with stock 3/4 63" springs
    people with the ORD flip please help
    Mudlug
    midnightwebmaster
  2. bshewmaker
    bshewmaker Registered Member
    Sep 11, 2003
    79
    Arkansas
    Try the search function on this site, and/or post in the ord forum. I can count 3 shackel flip/towing post that I have read recently off the top of my head
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    That wasn't too helpful. /forums/images/graemlins/crazy.gif
    Mudlug:
    Welcome to CK5. As you've just been told, there is a search feature, but since you asked a rather specific question and asked for people's opinions, I see nothing wrong with your post.
    I don't have an ORD flip. I do know it's not recommended if you tow with your truck (especially the kind of weight you're talking). I personally would choose a 6" lift spring over the flip/stock spring in your situation.
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We have a couple of trucks with shackle flips.....
    The nice thing about the 3/4T spring is it will have a higher load rating than a lift spring, which by the way only comes up to a 5" lift as far as I know. When you're hauling, the spring's rate and capacity will have more to do with the load carrying capability than the shackle mounting method. That's one of the cool uses of the flip, you get to keep a heavy rated stock type spring if that's what you want.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would not tow with a shackle flip. The geometry of it just seems to make the springs feel too soft. With super stiff stock springs I am sure it could be done, but in my opinion, by the time you get those, plus the flip brackets and new bushings, it will cost about the same as lift springs and I doubt you'll have any additional flex with the shackle flip and super stiff springs.
    I have a shackle flip on my trail machine, but my tow rig would run blocks or springs for sure.
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I towed all last year with a shackle flip. All I can say is, anything that works really well offroad, doesnt work all that well onroad. Such as the shackle flip. The shackle flip will make your rear soft. I wouldnt be too concerned with small weights, such as under 2000 lbs, but above that, your talking some more tongue weight. your k20 would have at least a 400-500 tongue weight, and you may get some uncontrolable bouncing and what not. If you want to tow with shackle flip, I would personally recommend no less than a good anti sway and weight distribution setup. That will keep the trailer and truck on a flat plane.
  7. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I towed with my 1 ton truck with the flip for 2 years with no problems. And thats everything from a 3 axle gooseneck loaded with 2 trucks to our dump trailer every weekend loaded upwards of 10k pounds.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Your truck also has nearly 170" of wheelbase, which I believe to be a big factor in this entire discussion.
  9. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Nearly, it's 171.5" thank you very much /forums/images/graemlins/waytogo.gif /forums/images/graemlins/rotfl.gif
  10. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Ya, but you got a 1 ton, he's got a 1/2 ton. Even if he upgrades his axles, he would still have to upgrade his rear springs to the 1 ton stock springs + flip to get closer to your load rating.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Damn, I thought it was 168". Sorry, your wheelbaseness. /forums/images/graemlins/bow.gif
    I guess my truck is tiny at 119". /forums/images/graemlins/rotfl.gif
  12. Mudlug
    Oct 3, 2002
    5
    San anontio TX
    well first off I did the search and found lots of topics about off road, none about on road and towing.
    The new dodge 1/2 tons have flips on them
    so i was just looking for info
    thanks for all the info I think I am going to go with the springs
    but the more input the better
    thanks
    everyone
    Laters
    Mudlug
    midnightwebmaster
  13. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,069
    206
    Colorado
    Okay, rant on, so now we are comparing towing with 1/2 ton trucks with loads that may be to heavy for them in stock form:
    Lifting them, adding larger tires, gears maybe?, probably less than optimum hitch setups as far as angle is concerned, and a short wheelbase. This is now a scary setup to tow with but somehow its all the shackle flip that causes it.
    I have a shackle flip on my 95 Ford Extended Cab longbed. I had the ability to tow the same trailer and load with no lift, 2" spring lift and 2" block, and finally a shackle flip.
    The truck did tow differently when I lifted it originally. Then I began to play with combinations of lift and finaly did the shackle flip. The TRUCK TOWS NO DIFFERENT WITH A SHACKLE FLIP THAN IT DID WITH A 2" ADD A LEAF AND A 2" BLOCK.
    Same amount of lift, same shocks, and same springs( I have never taken the add a leaf out since the first lift version).
    I did get some weird things before I got the trailer angle correct with a drop hitch and adjusting the hitch height on the trailer.
    I think where these MYTHS come up is when somebody is wanting to take the Blazer with 6" overall lift, tires that are not really meant for towing, poor hitch and trailer tongue geometry, soft shocks, and tow their boat to the lake at maybe excessive speeds. This is not the correct setup to do this with.
    Tow with the correct equipment for the job.
    Lifted trucks do tow different than they would not lifted. Lift methods seem not to have a drastic effect on towing ability, only the fact that it is lifted
    Rant off
