Shackle flip and towing
Discussion in 'OffRoad Design' started by ryand7, Jan 2, 2003.
  1. ryand7
    ryand7 Registered Member
    Apr 22, 2002
    11
    Mountains of NC
    I have seen a few posts about the shackle flip kit and towing issues..Is it really a serious problem?? I am getting ready to install a 4 inch lift..4 inch springs up front and new stock springs and shackle in the rear..Is there anything aI should look out for?? The only thing that I tow is my boat..19fter..????
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    i have the ORD flip on the yellow blazer and have no problems towing at all /forums/images/graemlins/thumb.gif [​IMG]
  3. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    I just installed mine last month and had the same question. I towed my brothers stump grinder and trailer around yesterday. Probably only weighs about 3,000 lbs total but I didn't have any problems at all. Rides great, wheels great.
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    As far as towing is concerned, you can regard the flip much the same as a block, it's just creating a taller ride height.
    The problem is (which you've probably read 20+ times because I know I've written this at least that many times) towing a poorly set up trailer, or towing with a vehicle that's not set up to tow. K5's are bit short to be optimum tow rigs but can do it if they're set up right, whether they have a flip kit or not.
    I know I'd rather tow with a flip kit than with a block for ride height, and unless you needed the stiffness of a deep arch spring, I wouldn't want a lift spring instead either.
    To answer your question specifically, towing in general can be a serious problem, for some vehicles and trailers. I know I've towed trailers with my K5 that were really bad and I could only run about 30 mph without wrecking. I've also towed a fairly heavy 20ft boat up to 70 very comfortably, the major variable in this case was the trailer, the truck didn't change much.
