Shackle Flip and vibes
Discussion in 'OffRoad Design' started by KRAZIE87K5, Nov 18, 2001.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I am thinking about acquiring a set of shackle flips from Steve, but I am SUPER WORRIED about vibrations. I can hit highway speeds with little to no vibes all the way to ~75mph.
    I have a 6" suspension lift, and currently have 4" blocks installed [​IMG][​IMG], and I would love to get them out. Since I have a 6" skyJacker lift, what can i do to account for the remaining 2"? The ORD web site says "ONLY 4 INCH LIFT".
    Will I need to install shims to fix angle issues? I also have the xfer case dropped 1"...
    Any help is appreciated!
    <font color=red>GOT MUD???</font color=red>
    My license plate reads:<font color=blue> 8 YR SUV</font color=blue>
    <a target="_blank" href=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</a>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s
  2. Shorts
    Shorts 1/2 ton status
    Oct 16, 2001
    336
    CC & SA, Tx
    the shims should fix any off angles.
    options on the rear...
    - ORD flip($180?/$160?), 2" springs($200)
    - ORD flip, 2" block($15?)
    - ORD flip, 1.5"-2" add-a-leaf($30-$40), 1" 0-rate block(if necessary)($30)
    <font color=blue>Shorts</font color=blue>
    '94 K1500
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Dan,
    Whatever you decide to do, check and note your current angles. When you go with the flip and spring combo or whatever you choose make sure the angles stay the same...
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  4. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Well I'm about to do the same type of swap myself in the next few days.....(shackle flip to replace blocks) so I guess you can ask me later how that goes.
    Realistically, the vibration is not going to be from a block lift or shackle flip.....it's going to be a driveline vibration from almost ANY kind of lift. From what I've heard once you get to 4" of lift or above, the vibration issue is going to be there to some degree (no pun intended! [​IMG]) because of the angle of your u-joints and rear pinion.
    The solution seems to be going to a CV-style driveshaft....which is how I'd like to do mine once I get all the axle-swaps, and suspension stuff finalized....
    -Greg72
  5. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Since I havent been able to sell my truck, Im gonna start parting it out. I just bought the cv shaft. What t-case do you have (I forgot)?
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  6. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Outlaw,
    Not sure if you're talking to me or not....but mine's a fixed-yoke NP205....[​IMG]
    -Greg72
    '72 K5 Blazer - 427BB/TH350/NP205/6" Lift/35x12.50's
    <font color=blue>See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38</a>
  7. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    The one in the truck is a slip yoke 205 for a TH400 (6 bolt adapter) and the one in the garage is a slip yoke 205 for a TH350 (4 bolt adapter).
  8. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    when i first put in the flip kit i had to shim my pinion down 2.5 Deg. and it fixed the problem
    <font color=green>Chaz</font color=green>
    <a target="_blank" href=http://community.webshots.com/user/chaz88k5>http://community.webshots.com/user/chaz88k5</a>
  9. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Everyone here has pretty well laid it out. Keep the same angles, you should drive just the same. I would recommend going with a CV joint at some point in the future. I would suspect that you have fairly low (numeric) gears so your driveshaft speed is pretty low. If you swap up, it'll get worse and the cv joint shaft is more forgiving of that.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
