shackle flip install q...
Discussion in 'OffRoad Design' started by shaggyk5, Apr 5, 2002.
  1. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    Stephen, when puting in the 4" flip. does it really matter if the shackle faces foward or back? I accidentally put mine on open side fowards yesterday, if it will cause problems i will pull it off and turn them around, but as far as my tired eyes can see, it really wont make much difference.
    BTW, all the bushings and everything else has gone together flawlessly. thanks.
  2. shaggyk5
    1,610
    SE pennsylvania
    up to the tippy top.
  3. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yeah, I'm wondering this too. In the instructions it says to make sure put them in so the "front" sticker on them faces torwards the front of the truck. Well, uh, mine aint got no stickers/forums/images/icons/wink.gif.
  4. shaggyk5
    1,610
    SE pennsylvania
  5. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I believe the shackle brackets should be positioned so that the bolt that the shackle mounts to is closer to the from of the truck. Look on ORD's write up of the shop blazer, they have a pic of the rear suspension where the bracket is installed from a previous lift -but it is backwards-. Meant for a longer spring in a custom application I assume.
  6. shaggyk5
    1,610
    SE pennsylvania
    Your right, thats what I did. Im actually talking about the position of the shackle itself. In all the writeups and instructions ive read, It says to intall the shackle itself with the open side facing back. I accidentally intalled them open side fowards, but i cant really see a problem with it. I just want an official OK from stephen saying i can leave it like this, or the official order to turn it around and do like the instructions say.
  7. Ryan Melton
    Ryan Melton Registered Member
    Dec 15, 2000
    61
    Texas
    It doesn't matter which way the open side faces. I think the instructions have the opening facing rearward for "aesthetic" reasons. It just seems to look cleaner. I seem to remember Stephen mentioning this quite a while back, but I couldn't find the post.
    Ryan
  8. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Shackle position doesn't really matter, it does the same job facing either way.
    The flip does install with the shackle mounting point forward of the bracket centerline.
  9. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    These are the same things i had ?'s on so now i won't be lost tonite when i do my flip!!!
  10. shaggyk5
    1,610
    SE pennsylvania
    gotcha boss.
