Shackle Flip Installation Instructions Online, for all those who asked...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BorregoK5, Aug 24, 2002.
  1. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
  2. amm888
    amm888 1/2 ton status
    Jul 20, 2002
    309
    Woodland Hills, CA
    is it safe to do all that with just a hi-lift holdin' up the truck?
    gramma alex
  3. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I've used my high lift several times to swap out the brackets and shackles. You have to do one side at a time this way, lifting only one corner like you would changing a tire. Make sure you loosen all your bolts before you lift it so your not torquing them on the high lift. With one side lifted the springs twist just a little and installation is a little harder but definately do-able. As always though, its good to be safe about it and support the frame with stacked wood or anything you can muster up which can hold the weight.
