Shackle Flip Problem!!!!
Discussion in 'The Garage' started by jk5blazer, Mar 14, 2005.
  1. jk5blazer
    jk5blazer 1/2 ton status
    Jan 28, 2005
    306
    Braselton, Ga
    Did anyone else have a problem with the holes lining up right on your shackle flip?:confused: If so what did you do to correct it. Didnt know if I should weld it in place or just elongate the holes. Thanks
  2. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    What brand?
    I recently installed a used ORD flip on my K5 and the holes lined up fine. The holes in the flip were bigger than my frame so I drilled the frame to match.
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I had to elongate the holes.
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    No problems at all with my ORD flip
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Personally I'd elongate the holes, and then weld it.
  6. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I believe the instructions tell you to enlarge the holes, but it has been a while.
  7. jk5blazer
    Jan 28, 2005
    306
    Braselton, Ga
    yours came with instructions! Nice.:D Thanks guys for the help.
  8. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    my sky flip kit the holes in the frame and in the flip were both too small for the hardware they provided, instead of sending it back i just drilled the holes out to fit, i still have to get the two bottom holes there way way way off. i love the flip though adjustable beefy, great price im happy with it
  9. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    I would call the manufacturer and find out what they have to say about your problem.
  10. muddyblzr
    Nov 2, 2004
    623
    i should of probably gone with the ord flip but at the time it was on sale and im only 17 so money is very tight. i regretted getting it when i found the problem but its solved now
  11. jk5blazer
    Jan 28, 2005
    306
    Braselton, Ga
    Im with you, I don't mind the extra work, the cost was down and they are very beefy. I just wanted to see what you guys have done to fix yours.
  12. chevydan3
    chevydan3 1/2 ton status
    Nov 27, 2004
    409
    Reno, Nevada
    My Ord flip kit didn't line up with the bottom holes on one side and the side holes on the other side. I just stuck bolts in the holes i could, drilled the frame and bolted up the rest of the holes. Hope this helps, has been 1-1/2 years w/no problems.
