shackle flip q's
Discussion in 'The Garage' started by jones, Jan 20, 2005.
  1. jones
    jones 1/2 ton status
    May 17, 2004
    379
    IONIA,MI USA
    i'm looking into an ORD or homemade flip.i don't necessarilly need alot of lift.just want to clear 33"s.i was thinking about the 2.5" kit from ORD,but the front springs are only 2".i want it to be level.not even a slight rake if it'll be noticable.does anyone know how to solve this problem,or am i just being anal.with the home fab flip w/ 1/2t. springs,cutting the bottom out of the hanger,is it actually strong enough that way or did you box it.any tips for a first time homefabber.what about d/s length w/ the homebrew style.i just put $150 in to having one lengthened 2 weeks ago.trying to save $$$ to spend in other areas.pics/advice/pics/pics appreciated.thanks!p.s.how much lift gained the DIY way?
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    http://coloradok5.com/forums/showthread.php?t=126181
    I plan to use the front mounts from the rear spring of a 2 wheel drive truck. I think it will give me about 2" of lift and I will have the benefits of a compression shackle. I already have 5.5" lift springs in the rear and I just want a couple more inches of lift. If you are real picky you can always use ORD's 1" zero rates front or rear to adjust the ride height to your taste if whatever mods you do don't work.
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    2 vs. 2.5 inches.........that is kinda' anal ;) Seriously, I really don't think it would be noticable. Besides, most K5's sit a little lower in the back to begin with.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    he doesn't have a K5, he has a longbed truck. i don't think its gonna be that noticable. 1/2" over 11 feet, your rear springs probably sag a 1/2" anyway.
    you have to remember, youll have to rotate the pinion down with a shackle flip. not sure how far, but a long bed truck needs it with a shackle flip.
  5. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    The back is better a little higher so when you load that sucker up it wont sag as much in the back.
  6. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    If you use the front spring hangers use the 1/2 ton hangers, they are a little bit shorter than 3/4 ton hangers. I would just use block for 2".
