shackle flip q's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by coloradoblazers, Aug 26, 2001.
  1. coloradoblazers
    coloradoblazers 1/2 ton status Premium Member
    Mar 2, 2001
    506
    WY
    shackle flip q\'s
    Im on the second day of the shakle flip process. Besides Murphys Laws being in full effect I am almost complete. The only thing I need help on is getting the leaf spring off the front hanger. The nut is between the hanger and frame, so it is unacessable. The bolt is not gonna turn easily. How does everyone else get them off? (already went through several cans of liquid wrench, rust eater etc.)
    K-5- because size DOES matter!
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    Re: shackle flip q\'s
    have not had the pleasure of doint it yet but an air hammer maybe?
    dunno..
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  3. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    i have a truck, but i think the front hangers are the same, i went throught the top w/ a wrench and let it hit the hanger itself and manhandle the bolt off
    Hut in the well is goin on in here?
    sun desert offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
  4. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Well, if the bolt has been there for a while chances are its rusted to the sleeve inside. The best bet is just to avoid the headaches of trying to wrench it and just go ahead and cut it off. Cut on both ends of the bushing with a hacksaw or a cutting wheel, and pop the spring out, then knock the ends of the bolt out. Saves a lot of hassles and swearing.
    I finished my shackle flip and brake conversion last week, and I just cut everything off and replaced it all.
    Good luck
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Aint Skeered!! </font color=red>
  5. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    I did the same thing on my blazer :)
    -Aaron
    ___ __ _ _ ____ __
    AGM73k5 -- ajgm1@yahoo.com
  6. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    I used a long wrench (I forget the size). I angled it in on the nut. (the side where the frame blocks half of the hanger) and then used an impact wrench on the bolt side and took it off that way.
    OR,
    I did this on my older truck a while back when I did the shackle flip (did it twice to two different trucks),
    Was I took that same long wrench and angled it in on the nut and took my 3lb sledge and started wacking it and that got the nut off (or should I say, loose) :) Good luck
    Boss
    Pic of my truck Before N' After
    <a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
