Shackle flip Q's
Discussion in 'The Garage' started by Jonny-K5, Jun 25, 2003.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    Shackle flip Q\'s
    ive got 3" fronts i want about 3-4" of lift for rear . i dont want to go thru the hassle and cost of the ord flip. i like everything about the echobit flip exept the 5.5 lift. is there anyway i can get that closer to 4? maybe remove the overloads? ideas? should i just bite the bullet and do the ord. i like the idea of a homeade " cut the stock hanger" idea causs its free, and only 3-3 1/2" lift. but it just seems weak. ideas?
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Re: Shackle flip Q\'s
    Go with the cut through the hanger - It should put you right in the ball park of what your after. It does make it a little weaker but everything is a trade-off. If you can gusset the top, you can make up for it. The only draw back over my flip or the ord flip is both relocate the shackle mount forward by 1" for better droop.. you wont get this with a cut through.
  3. Shorts
    Shorts 1/2 ton status
    Oct 16, 2001
    336
    CC & SA, Tx
    its not weak unless you don't add a support strap. here's what i did on mine:
    as stated above, this doesn't move the mounting point forward, so you'll lose a little flex.
  4. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Thats exactly the type of gusseting I was speaking of! Nice! My stock hangers are still cut through even though I'm not using it that way anymore. /forums/images/graemlins/grin.gif
  5. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    thanks guys, i think i'll go with the cut thru design, for now. did you weld the upper part of that gusset to the hanger? isn't that unsafe so close to the fuel tank?
  6. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    posting this link for about the zillionth time. Tons of people doing shackle flips. This way is rather inexpensive and uses a factory bracket without cutting it. I welded it in but it can be bolted.
  7. Shorts
    Oct 16, 2001
    336
    CC & SA, Tx
    yeah, i welded the sides and top of that strap. its not close to the tank; i have a truck.
  8. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    Oh, well i guess i could jam some plywood or sheetmetal between the tank and frame to keep the hot stuff away. thanks again for the input. /forums/images/graemlins/grin.gif
  9. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    decisions decisions... what tools to use for this cutting of the hangers. my options are 4" angel grinder, sawzall,cutting torch,big drill. I'd like to torch causs it would go much faster. but i dont want to get blown up. My uncle thinks its a bad idea as well to be torching so close to the gas tank. so im leaning towards drilling some pilot holes and using the sawzall to keep the sparks down. what do you all think? i want to do this asap, this weekend if possible
  10. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Hey, ive been brainstorming my shackle free shackle flip ideas, and thats the best ive seen and it is what im gonna do now, THANKS /forums/images/graemlins/thumb.gif
