shackle flip question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by stan1688, Jan 4, 2007.
  1. stan1688
    stan1688 1/2 ton status
    Sep 13, 2006
    779
    Independence, KS
    Did a search and didnt find much. Would a 2 1/2 inch shackle flip, with a 6 inch shackle give me 4 inches of lift with 56 inch rear springs (I think thats what my 91 k5 has)? Would it move my axle any? Anyone running this set up? Thanks.
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    The shackles will lift the vehicle half the difference in the extra length. So if the shackle is 1" longer than stock it will lift the vehicle 1/2". Blazers are all 52" springs in the rear from the factory. You would need a shackle that is 3" longer than stock with a 2 1/2" shackle flip to get you 4" of lift. I would highly advice against going that much length on a shackle. Why not just buy a 4" shackle flip and sell the 2 1/2" ?
  3. stan1688
    Sep 13, 2006
    779
    Independence, KS
    I dont have a shackle flip yet but im going to be getting one. Dont longer shackles help with articulation?
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Trust me , stock shackles , and a 4 inch flip , you will hit the inner bedsides with your top inner tire edge easy .
  5. stan1688
    Sep 13, 2006
    779
    Independence, KS
    Thanks for all the input.
  6. iwaxmyjimmy
    iwaxmyjimmy College web wheeler Premium Member
    Nov 3, 2006
    2,802
    34
    Greenville NC
    also w/ only a 2.5 shackle flip and a 7inch would be a horrible shackle angle(ride and flex will suffer) with ur stock 52inch springs. but a 4inch shackle flip and swaping the sides w/ a 6inch shackle flip is starting to be the normal for 56inch springs.
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    There's more to it than simply a longer shackle. You have to have the proper shackle angle for a longer shackle to give you more droop. For example, if the shackle is straight up and down a longer shackle will only give you a little more lift, but not make any difference in the articulation.
  8. stan1688
    Sep 13, 2006
    779
    Independence, KS
    Thanks everyone for all your help.
