Shackle flip question
Discussion in 'OffRoad Design' started by 77Blazer, Sep 5, 2001.
  1. 77Blazer
    77Blazer 1/2 ton status
    Aug 13, 2001
    197
    Long beach CA
    Stephan-
    I want to use my 4inch springs that i currently ride on with the shackle flip but which would be more cost effective... buying new 6inch fronts and 2inch rears or going with the 8inch up front and opening up some steering/ drive shaft angles concerns.
    350, sm465, NP205, 14 Bolt w/Detroit locker(465 ratio), yucky ten bolt,38.5 swampers
    <a target="_blank" href=http://www.planettribes.com/theden/gontw/nsig.jpg>http://www.planettribes.com/theden/gontw/nsig.jpg</a>
  2. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    I say go with a 6" sping and a 2" block in the rear. You are going to have to do some drive shaft work no matter what.
    1987 Jimmy Sierra Classic, Palisades Park, NJ 07650
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I'd say stay with the 6" plan and lift the rear however you can afford. You could do the 2" spring, or a 2" block, or use a 2.5" flip and your 4" spring. With a 6" lift, your front driveshaft isn't really going to work without a little clearance grinding and maybe a limit strap on the right side, so going to an 8" is a little too much I think.
    Get some axles for those tires.....:-)
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    SW-ORD
  5. 77Blazer
    Aug 13, 2001
    197
    Long beach CA
    hey im half way there!!! give me some slack im still a college student :) i had the dana 60 but with my tuition being 20k a year I had to part with it b4 it went on.
