Shackle Flip Question
Discussion in 'OffRoad Design' started by tomseviltwin, Mar 10, 2002.
  1. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    I saw this on other post. Any drawbacks in using a two inch lowering shackle flipped over for additional rear lift on my suburban? Part# SUM-G756
    Thanks,
    Tom
  2. steve_97
    steve_97 Registered Member
    Feb 27, 2002
    25
    Boise, Idaho
    Im using bell tech 2" lowering shackles with a 4" shackle flip on my '73 k5 and with using 2.5" rear blocks, so I am running the blocks backwards to get the pinion angle close.
    steve
    Steve_97@hotmail.com
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The big problem with a longer shackle is that the back of the spring will be dropped a good bit and as it drops it can mess with the handling. It's a matter of degree. We do have customers combining the longer shackles with the flip so it does work but you should be aware of the drawbacks. Basically you get roll oversteer (truck gets loose in corners) and it can become a ground clearance issue in some cases.
  4. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    yes it sure can....last year at Tellico, DepDog dropped off a rock ledge and bent his like this << (as viewed from the rear). when he got home, he beefed 'em up by welding on steel pieces. They are very beefy now. i recently installed a pair and havent really noticed too much difference in handling, but it already drives like a "peach" with the 38.5 TSL/SX's anways /forums/images/icons/crazy.gif/forums/images/icons/crazy.gif
  5. tomseviltwin
    Dec 23, 2001
    2,065
    Utah
    " already drives like a "peach" with the 38.5 TSL/SX's anways ." I'm sure it does (LOL) Thanks to all for the input.
    tom
