Shackle flip question
Discussion in 'OffRoad Design' started by Swanson52, Apr 2, 2002.
  1. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Just got the ORD shackle flip for my 83 Blazer. Any input on the easiest/most efficient way to remove the factory rivets from the tension shackle bracket?
  2. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    4" angle grinder is what i used. it worked, but sucked (i hate grinding)
    later rob
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    I didnt have a grinder, so I drilled the heads off and pounded the rivet shafts out with a center punch and sledge hammer. Worked for me even tho it was much more of a PITA than a grinder woulda been. There are pics of the whole install on my webshots...
    J
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    A BURLY (probably snap on or equivalent quality) air chisel is the best way. You can smack the rivets with that thing and they just go away. A poor air chisel is a waste of time.
    Next up I'd look at drilling since it's less mess/noisy than a grinder. Grinding does work well though. If you're good with a torch and have all the flamable stuff out of the way you can torch the heads. That's a trickier operation.
  5. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Since I already had the gas tank out anyway, I used an acetalene torch. It took less than 2 minutes to completely remove the factory brackets. Just watch out for any wires or fuel lines behind the frame rails.
  6. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    I just did this tonite. Way easier than I expected. I used a grinder, (yeah i know its not the fastest or easiest, but with a good wheel it didnt take much time) Ground the heads off and then hit the BRACKET itself with a BFH. this popped off after a minute or 2 of good hits, leaving the irvits sitting there waiting to be knocked out of the frame (easy). Dont even bother punching the rivets out first.
