Shackle flip question...
Discussion in 'OffRoad Design' started by MilpitasK5, Apr 26, 2002.
  1. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    I have a 3 inch lift in the front and a 3.5(blocks) in the rear. I hear that I can do an ORD shackle flip in the front to level iit out (need another .5 in the front). Is this true? If so which one do I get?
    Thanks,
    Chris
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    you would get the 4" ORD rear flip (no front)
    the Extended shackles add about 1/4" or you would add the zero-rates.
  3. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    but I'm just tryin' to get another .5 in the front so your sayin' I should just get the zero rates? The shackle flip will eliminate my blocks, right?
    Thanks Zakk! How's that poison oak?
  4. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Food for thought, ever see a k5 without sag in the rear? well, i did a flip and the extra .5-1.0 inch only helped level it.. WOO-HOO!!!
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    right, the flip will eliminate the need for blocks.
    see my post in Nor-Cal section as to an update/forums/images/icons/laugh.gif
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I'd say get the 4" flip, you might not need any extra front height to level it. But the shackles do add 1/4" and we have zero rates in 1/2" and 1" if you need them.
  7. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    my front end is what needs to be raised though. I definitely want to go with the shackle flip but I need to get the front up.
    What are zero rates? I didn't see them on the catalog either. Greg72 was explaining it to me @ Hollister but that was a whiles back.
  8. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Never mind the question about the zero rates. I found 'em. Thanks,
  9. 1bad82k5
    1bad82k5 1/2 ton status
    May 8, 2001
    185
    MT
    I think I have the only k5 in history to sag more in the front than the rear. I guess my stock springs are just hailed out. Mine actually sits higher in the rear than the front. I have no lift and stock springs.
    eric
  10. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    The problem I had was I installed brand new front springs...4" from Rough Country and installed shackle flips in the rear and mine sags. I'm going to add and add-a-leaf in the rear to help level it out. Also...does anyone know why my lower leaf spring (the flat one) moves. It keeps twisting out and i have to knock it back straight every once in a while. I have tight u-bolts and it never did it before I seperated, cleaned and painted them.
  11. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    i used the tuff country 6" spring (frnt) and shackle flip w/2" block the only reason mine sags is my stock rears are flat!!
  12. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I would recommend a full length Skyjacker add a leaf. To keep your overloads straight, you need a bolt style spring clamp.
  13. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    i second that, use a bolt style, and to make it ez to put in a bolt, use c clamps /forums/images/icons/wink.gif and then r/r them .it keeps em together.
